Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Suggestion: add more info to GPA Geometry tab
Tomas_B_
Is there a way in the geometry tab to see more information per-vertex than just a position. I would like to see all the vertex attributes set to the vertex declaration and the whole output of the VS for the VS stage. That's many times a hint what is going on there.
Usually (in PIX) I debug particular vertices that I select using index buffer. Is there any similar option in the GPA? It would be also great if I can select a vertex directly using a mouse click into the mesh preview window.Thank you!
Tomas
Neal_Pierman
Valued Contributor I
Thanks for the suggestion! I've forwarded your suggestions to the team for consideration in a future version of the product.
Neal
