Intel® HPC Toolkit
2136 Discussions
A Weird Problem about libmpigi
ZQiang
I'm compling a project based on PETSc and SLEPc. When I use command
mpiicc -mkl=parallel -o $@ $< -Wl,-rpath,${MKLROOT}/lib/intel64 -L${MKLROOT}/lib/intel64 (and a lot of other libs) -lmpi -lmpigi
I got a error msg
ld: cannot find -lmpigi
And then I found a similar question on board, it was said that libmpigi no longer existed, and it was included in libmpi.a. However, if I remove option -lmpigi, another problem came to me
ld: warning: libfabric.so.1, needed by /home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so, not found (try using -rpath or -rpath-link)
../lib/libgcge_slepc-3.0.a(gcge_app_slepc.o): In function `SLEPC_LinearSolverCreate':
/home/forzzig/GCGE-1.0-master/app/slepc/gcge_app_slepc.c:52: undefined reference to `PCHYPRESetType'
/home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so: undefined reference to `fi_tostr@FABRIC_1.0'
/home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so: undefined reference to `fi_dupinfo@FABRIC_1.1'
/home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so: undefined reference to `fi_strerror@FABRIC_1.0'
/home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so: undefined reference to `fi_freeinfo@FABRIC_1.1'
/home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so: undefined reference to `fi_fabric@FABRIC_1.1'
/home/forzzig/intel/oneapi/mpi/latest/lib/release_mt/libmpi.so: undefined reference to `fi_getinfo@FABRIC_1.1'
How should I fix this issue?
ShivaniK_Intel
Could you please provide us the version of Intel MPI you have been using?
Could you also provide the sample reproducer code to investigate more on your issue?
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks & Regards
Shivani
ZQiang
I've solved this problem by adding ${MPIROOT}/libfabric/lib to the lib path.
And PCHYPRESetType is another problem caused by the package I used, not about intel mpi.
Thanks all the same!
ShivaniK_Intel
We are glad that your issue has been resolved. We will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thanks & Regards
Shivani
