Intel® HPC Toolkit
MPI_Init_thread or MPI_Init failed in child process
Yongjun_L_
I have two programs, A and B. They all are developed with MPI. A will call B.
If I directly start A and call B, every thing is OK.
If I start A with mpiexec, like mpiexec -localonly 2 A.exe, and call B. MPI_Init_thread or MPI_Init will fail in B.
Below is the error message I got.
[01:2668]..ERROR:Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
[01:2668]..ERROR:Connect on sock (host=localhost, port=53649) failed, exhaused all end points
SMPDU_Sock_post_connect failed.
[1] PMI_ConnectToHost failed: unable to post a connect to localhost:53649, error: Undefined dynamic error code
uPMI_ConnectToHost returning PMI_FAIL
[1] PMI_Init failed.
Fatal error in PMPI_Init_thread: Other MPI error, error stack:
MPIR_Init_thread(659):
MPID_Init(154).......: channel initialization failed
MPID_Init(448).......: PMI_Init returned -1
Can anyone tell me what is the problem? How to solve it?
Yongjun
Gergana_S_Intel
Hi Yongjun,
You'll have to give us more details on how exactly you call B from A.  Is program A a script that simply calls B?  Or do you mean you're spawning a process from A that then executes B?
If you have 2 executables, you can use argument sets to run both of them simultaneously:
mpiexec -localonly -n 1 A.exe : -n 1 B.exe
Looking forward to hearing back.
~Gergana
Yongjun_L_
Hi Gergana,
Than you for your reply.
A and B are two separate executable files.  B must be called from A.
A use API to start B and pass argument to B. There is no communication between A and B.
Yongjun
Yongjun_L_
Hi Gergana,
I want to start multiple As on different computers and each A will start B with different argument. A doesn't need use mpiexec to start B.
Yongjun
Gergana_S_Intel
Thanks for clarifying, Yongjun.  Are A and B both MPI applications?  Or is A non-MPI but B is an MPI application?
Yongjun_L_
A and B are both MPI applications.
I start two A on two computers. The command is
      mpiexec -np 2 -machinefile host.txt  A.exe
Each A will start B with different argument
      system( "B arg1" );
MPI_Init_thread will fail in B and cause B crash.
Gergana_S_Intel
That's not a supported model.  Most likely what's happening here is: prog A gets initialized correctly and has the global communicator (MPI_COMM_WORLD) properly defined.  Then prog B starts from within A but it's unable to get initialized.
Can you run B as a stand-alone?  I looked back in the thread but didn't see that scenario.  You only say that A starts outside of mpiexec.
Alternatively, have you tried doing system("mpiexec -localonly B arg").  I don't know if that'll work but might be worth a try.
I'll ask around and see if anyone has worked on a similar application before.
~Gergana
Yongjun_L_
Hi Gergana,
Of course I can run B as standalone.
I tried to use mpiexec -localonly 1 B arg to start B before. It doesn't work for me.
The only problem is that if I use mpiexec to start A, B will fail.
Yongjun
