Intel® HPC Toolkit
2140 Discussions
Unable to compile Timer sample (timertest.c, timerperformance.c)
Phreak__Phone
"This example provides functionality to test performance of the VT_timestamp() function."
"Ensure that the corresponding compiler, Intel MPI Library, and Intel Trace Analyzer and Collector are already in your PATH"
When trying to build (make) the example, all I can get is the following error message:
"You need to set VT_ROOT env variable to use Intel(R) Trace Collector"
What should I do to set up the proper environment to compile only this utility ?
The utility is attached to this message as a ZIP file.
