Intel® High Level Design
Acceleration stack
student1
If I want to use intel PAC cards with oneAPI DPC++,should I also install the Acceleration stack software?
Thank you.
Dilanjan_J_Intel
Hi student1,
Thank you for posting in the Intel Communities. Since your question is related to the Intel® FPGA Acceleration Cards we are moving this topic to the Intel® High-Level Design community.
Dilanjan
JohnT_Intel
If you would like to use the BMC and update the board then it is recommended to install the accelleration stack. If you are only testing the OneAPI then you do not need to install it. You may refer to https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/set-up-a-system-for-fpga-with-the-intel-pac/install-intel-fpga-add-on-for-oneapi-base-toolkit-package.html for how to setup the FPGA for OneAPI.
