Intel® High Level Design
722 Discussions
CL_INVALID_BINARY when running fast_recompile example (from oneapi_cli)
asenjo
Innovator
I've followed the steps to compile the fast_recompile example that is available via oneapi_cli. I got this error when trying to run it:
u32284@s001-n081:~/code-samples/fast_recompile/build$ ./fast_recompile.fpga
Running on device: pac_a10 : Intel PAC Platform (pac_ee00000)
Caught a SYCL host exception:
Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
terminate called after throwing an instance of 'cl::sycl::runtime_error'
  what():  Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
Aborted
Thanks in advance,
Rafa.
asenjo
Innovator
Ok, looks like I have to be in the right node with the right FPGA. If I compile for the Arria10 I can run in a node with Arria, but if I compile for the Stratix10 (-DFPGA_BOARD=intel_s10sx_pac:pac_s10) I have to look for another node with the right FPGA:
u32284@s001-n081:~/code-samples/loop_unroll/ArriaBuild$ ./loop_unroll.fpga
Input Array Size:  67108864
unroll_factor 1 kernel time : 242.849 ms
Throughput for kernel with unroll_factor 1: 0.276 GFlops
unroll_factor 2 kernel time : 122.319 ms
Throughput for kernel with unroll_factor 2: 0.549 GFlops
unroll_factor 4 kernel time : 63.950 ms
Throughput for kernel with unroll_factor 4: 1.049 GFlops
unroll_factor 8 kernel time : 39.567 ms
Throughput for kernel with unroll_factor 8: 1.696 GFlops
unroll_factor 16 kernel time : 37.500 ms
Throughput for kernel with unroll_factor 16: 1.790 GFlops
PASSED: The results are correct
u32284@s001-n081:~/code-samples/loop_unroll/ArriaBuild$ cd ..
u32284@s001-n081:~/code-samples/loop_unroll$ cd StratixBuild/
u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$ ls
CMakeCache.txt  cmake_install.cmake  compile.sh.e726724  loop_unroll.fpga  Makefile
CMakeFiles      compile.sh           compile.sh.o726724  loop_unroll.prj   src
u32284@s001-n081:~/code-samples/loop_unroll/StratixBuild$ ./loop_unroll.fpga
Aborted
Then, reading here: https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
I found how I can request the right node. The problem now is that I'm not authorized:
u32284@login-2:~$ devcloud_login -b A10PAC
You are already logged into node  interactively.
Invalid Entry. Valid development stack options are: 1.2 1.2.1
eg: devcloud_login -I A10PAC 1.2
You are selecting an interactive compute server sesssion. Please consider using batch mode submission using
devcloud_login -b to not tie up compute servers with idle sessions.
See the help menu using devcloud_login -h for more details.
What are you trying to use the Devcloud for?
1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL
2) Arria 10 - OneAPI, OpenVINO
3) Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL
4) Compilation (Command Line) Only
5) Enter Specific Node Number
Number: 3
running: qsub -q batch@v-qsvr-fpga -I -l nodes=s001-n189:ppn=2
qsub: submit error (Unauthorized Request  MSG=group ACL is not satisfied: user u32284@login-2, queue batch)
Any help?
Rafa.
asenjo
Innovator
Aborted
Number: 3
Any help?
Rafa.
ChithraJ_Intel
Hi Asenjo,
As checking your query, we could find that you are using FPGA devcloud. So, we are moving this query to FPGA forum for a faster response.
Chithra J
AnilErinch_A_Intel
There is an access control list (ACL) for each of the nodes. If you want to access s10 , please put up a request with your local intel contact point and they should be able to help.
Thanks and Regards
Anil
