Intel® High Level Design
636 Discussions
Can't find Quartus prime lite 21.1 Modelsim_ase\win32aloem file
Raphaier
Due to no this file, so CAN'T do the timing simulation.
Can someone let me out? Thanks.
SyafieqS
Hi Raph,
Seem like you are confuse between functional simulation and timing simulation.
If you would like to do timing simulation, you can easily static timing analyzer in quartus --> tool
Speaking of functional simulation you can use Questasim for 21.1 Lite edition. Specify the directory properly that should be working.
Modelsim no longer available in 21.1 Lite
Raphaier
Hi ,
Below attached is currently I have file, could you specific tell me the directory? Thanks.
SyafieqS
Hi Raph,
That should be in /21.1/questa_fse/win64 since you are using free version.
fse is free version but you still need to generate license. Can take a look below link how to do so.
https://www.youtube.com/watch?v=F6FvXga4f1A&t=235s
SyafieqS
Hi Raphaier,
May I know if you able to solve this? Let me know if there is any concern from your end
p/s: If any answer from Intel Support are helpful, please feel free to rate 10/10 survey
Raphaier
Hello guy
I had followed this video step by step to get a license file and set the LM_LICENSE_FILE variable, and also set the license file path, and also done the Tools license setup, but the Quartus system still CAN'T get the license file.
It seems many tricky.
SyafieqS
Hi Raphaier,
May I know if reinstallation the Quartus resolve the issue? Reinstall and go through the same step as in the video again. Let me know about that.
If still persist we can have a quick call to sort this out. Let me know about that as well
SyafieqS
Let me know if there is any update from your end
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
