Intel® High Level Design
722 Discussions
Error enumerating AFCs: not found on dev cloud
adarsh_m
hello ,
i have again started facing error 139 and Error enumerating AFCs: not found in all my jobs submitted on fpgas.
Please look into it ,why the similar issue keeps  coming and going again  and again.
iramovs
Yeah, almost every arria 10 node seems to be affected by this right now. Output of aocl diagnose on node s001-n084:
ICD System Diagnostics
Using the following location for ICD installation:
        /etc/OpenCL/vendors
Found 4 icd entry at that location:
        /etc/OpenCL/vendors/intel-neo.icd
        /etc/OpenCL/vendors/Altera.icd
        /etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
        /etc/OpenCL/vendors/intel-cpu.icd
The following OpenCL libraries are referenced in the icd files:
        libigdrcl.so
        libalteracl.so
        libintelocl_emu.so
        libintelocl.so
Checking LD_LIBRARY_PATH for registered libraries:
        WARNING: libintelocl.so NOT FOUND
Using OCL_ICD_FILENAMES to search for ICD clients, it is set to libintelocl_emu.so:libalteracl.so:/glob/development-tools/versions/oneapi/2021.3/inteloneapi/compiler/2021.3.0/linux/lib/x64/libintelocl.so
Checking LD_LIBRARY_PATH for registered libraries specified by OCL_ICD_FILENAMES
        WARNING: libintelocl_emu.so NOT FOUND
        libalteracl.so was registered on the system at /glob/development-tools/versions/oneapi/2021.3/inteloneapi/compiler/2021.3.0/linux/lib/oclfpga/host/linux64/lib
        /glob/development-tools/versions/oneapi/2021.3/inteloneapi/compiler/2021.3.0/linux/lib/x64/libintelocl.so was registered on the system.
Using the following location for fcd installations:
        /opt/Intel/OpenCLFPGA/oneAPI/Boards
Found 2 fcd entry at that location:
        /opt/Intel/OpenCLFPGA/oneAPI/Boards/intel_a10gx_pac.fcd
        /opt/Intel/OpenCLFPGA/oneAPI/Boards/dcp_bsp.fcd
The following OpenCL libraries are referenced in the fcd files:
        libopae-c.so
/opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libMPF.so
/opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so
        /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so was registered on the system.
Number of Platforms = 3
        1. Intel(R) FPGA Emulation Platform for OpenCL(TM)              | Intel(R) Corporation           | OpenCL 1.2 Intel(R) FPGA SDK for OpenCL(TM), Version 20.3
        2. Intel(R) FPGA SDK for OpenCL(TM)                             | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 2021.3
        3. Intel(R) OpenCL                                              | Intel(R) Corporation           | OpenCL 2.1 LINUX
ICD diagnostics PASSED
BSP Diagnostics
Error parsing device name '����'
Device Name:
acl0
BSP Install Location:
Vendor: Intel Corp
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
