Intel® High Level Design
722 Discussions
Error opening AFC: insufficient privileges
lcruz
I have FPGA integrated into compute nodes. But, recently, I have note been able to use them. When I load the intel/2021.3.0 compiler the following messages are returned:
Or other times it returns:
Failed to configure device acl0:pac_ed00001|BSP_UNLOADED|PASSED
What does it means? And how should I fix it?
aikeu
Hi lcruz,
Sorry for late respond. May I know some additional information from you regarding the below:
  1. Which tools you are using? IOFS? oneAPI? OPAE?
  2. Are you using intel devcloud to compile the design?
  3. Can you share more details on the design or command used to compile the project?
  4. Are you running the command with root access?
Aik Eu
aikeu
Hi lcruz,
Any follow up from the previous comment?
Aik Eu
aikeu
Hi lcruz,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
ndevenish
This sounds very similar to the issue I had https://community.intel.com/t5/Intel-High-Level-Design/Configuring-for-non-root-user-access-without-quot-Error-opening/m-p/1402918#M2603 - this turned out to be that my user didn't have sufficient permissions to read/write from the raw devices.
So either running the tooling as root worked or (preferably) changing the device permissions might work.
Nick
