Intel® High Level Design
722 Discussions
Error: pll_rom: Failed to find module opencl sdk standard 19.1
MMATT35
Hello I try to run the hello world example with a c5soc, but I have this error when quartus try to synthesize the design :
Error: pll_rom: Failed to find module system_acl_iface_acl_kernel_clk_pll_rom
Do you know how can I fix that ?
HRZ
Valued Contributor III
What is the exact name of the board you are using and what BSP version for that board are you using?
