I am trying to follow the oneAPI example on the "hello world"-like vector-add example. Running "make hw -f Makefile.fpga" and "make run_hw -f Makefile.fpga" works fine. However, when I switch to the USM code using "make hw_usm -f Makefile.fpga/ make run_hw_usm -f Makefile.fpga", I get an error. The build appears fine, but the run returns with "Shared memory allocation failure".
Any thoughts as to what is failing? Are there log files that I should be looking at to get more details on the error?
Hi TomT,
We are able to reproduce the issue. We will check with the concerned team and let you know regarding the issue.
Arun
