Intel® High Level Design
722 Discussions
FIM and BMC firmware version issue when upgrade Intel OneAPI 2021.2.0.2883 (latest version)
Yung__Sargen
FGPA FIM and BMC firmware version is not updated when install OneAPI base kit 2021.2.0.2883
I just try to upgrade my OneAPI base kit version 2021.1 beta 6 to 2021.2.0.2883 with intel FPGA addon . After installing the base kit and addon, I try to run
aocl install intel_a10gx_pac
 in order to install intel PAC software stack for my 2 intel arria 10gx PAC in the same machine. Unfortunately, it failed because the FIM and BMC firmware version is not updated to the targeted FIM version 38d782e3-b612-5343-b934-2433e348ac4c. here is the output from command fpgainfo fme:
//****** FME ******//
Object Id : 0xED00001
PCIe s:b:d:f : 0000:D8:00:0
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Bitstream Id : 0x123000200000185
Bitstream Version : 1.2.3
Pr Interface Id : 69528db6-eb31-577a-8c36-68f9faa081f6
Boot Page : user
Board Management Controller, microcontroller FW version 26889
Last Power Down Cause: POK_CORE
Last Reset Cause: None
Object Id : 0xED00000
PCIe s:b:d:f : 0000:3B:00:0
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Boot Page : user
From the output, we can see the FIM verison is 69528db6-eb31-577a-8c36-68f9faa081f6 which is one version older than the target which caused the failure.
Would someone give me some hints why the firmware update fails when running aocl install intel_a10gx_pac and how the firmware can be upgraded to the target version properly?
BoonBengT_Altera
Hi @Yung__Sargen,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
Please do refer to the section "Update the Firmware on You Intel PAC" in the link here for details steps, and do let us know if that helps.
Best Wishes
BB
BoonBengT_Altera
Hi @Yung__Sargen,
Greetings, unfortunately as we do not receive any further clarification on what is provided. Hence thread will now be transitioned to community support. If you have new queries, please feel free to open a new thread and we will be right with you. Otherwise, the community users will further help you with doubts in this thread. Pleasure having you here.
Best Wishes
BB
