Intel® High Level Design
FPGA
Linshen_liu
I need to use a cyclone 10 GX work as an E-load, that means a load curent change with high slew rate, what should I do to design a such that system on that board.
Farabi
E-load circuitry require many analog components such as OP AMP and resistors. This implementation is not suitable to use FPGA as FPGA only implement transistor logic (Digital signals) inside them.
regards,
Farabi
Farabi
regards,
Farabi
Fakhrul
Hi Linshen_liu,
You may refer to the answer provided by Farabi above. In anticipation that your question has been answered. We will be transitioning this thread to community support. If you have any new questions or concerns, we kindly suggest opening a new thread to receive assistance from Intel experts. However, if you do not have any further inquiries, the community users will be available to assist you on this thread. Thank you for your understanding.
