Intel® High Level Design
722 Discussions
Fpga device not found on oneAPI
Chithambarash
I recently installed oneAPI. I have an fpga connected to my device however when i compile and try to run on the fpga, i cannot find the device on oneapi.
Fpga used is Arria10.
aikeu
Hi Chithambarash,
Can you show me the related environment interface or error which you have encounter?
Aik Eu
Chithambarash
I'm able to run the program on cpu.
aikeu
Hi Chithambarash,
After I have consulted the team, you will need to run through board initialization first.
Can refer to the related steps as below:
https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2023-0/fpga-board-initialization.html
Aik Eu
Chithambarash
This is the error i'm getting
aikeu
Hi Chithambarash,
Can double check if you are using the correct board variant "pac_a10" in your input command?
aocl initialize <board id> <board variant>
Aik Eu
aikeu
Hi Chithambarash,
May I know any further update from the previous comment?
Aik Eu
aikeu
Hi Chithambarash,
I will close this thread if there is no further follow up regarding the matter.
Aik Eu
aikeu
Hi Chithambarash,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
