Intel® High Level Design
722 Discussions
Getting a gcc include error trying to build vector-add example for FPGA emulation using OneAPI on my local server.
JSchr20
I followed the FPGA OneAPI tutorial in https://devcloud.intel.com/oneapi/get-started/base-toolkit/#fpga-vector-add-sample-walkthrough and successfully built and ran the example on the dev cloud, both in emulation and in hardware. However, the FPGA build took quite a long time, so I'd prefer to build on my local server, which I think will be quicker. To that end, I downloaded the base toolkit for OneAPI, plus the FPGA add-on, and I installed both. I cloned the vector-add example locally, modified the tutorial's build_fpga_emu.sh to point to my local copy of inteloneapi, and tried to build. I get the following error:
In file included from /.alpha/public/inteloneapi/compiler/2021.1-beta05/linux/lib/clang/11.0.0/include/CL/sycl/intel/sub_group.hpp:18:
/.alpha/public/inteloneapi/compiler/2021.1-beta05/linux/lib/clang/11.0.0/include/CL/sycl/intel/functional.hpp:28:17: error: too few template arguments for class template 'less'
   return std::less<>()(std::forward<const T>(lhs), std::forward<const U>(rhs))
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/bits/stl_function.h:231:12: note: template is declared here
   struct less : public binary_function<_Tp, _Tp, bool>
I tried re-doing the installation while pointing at a previously-installed version 8.3.0 of gcc instead, but when all is said and done, I'm getting the same error. I'm guessing it's because the includes are still pointing to the default gcc 4.8.5 on my server. Maybe?
I'm an FPGA RTL designer, not a C programmer, so I'm not very familiar with how to point installations to correct versions of gcc. What am I doing wrong? Ancillary info: I do not have root or sudo privileges on this system. I must install these as a user.
Thanks for suggestions!
JohnT_Intel
May I know how do you performed the installation? Have you check your system environment? You could check the environment by running the command "env" in the terminal.
JSchr20
Hi John, thanks for responding.
My steps were as follows:
* open a terminal window
* download OneAPI base toolkit from https://software.intel.com/en-us/oneapi/base-kit:
* under 'download the toolkit' selected 'get it now'
* chose Linux, chose Online Installer, downloaded l_BaseKit_b_2021.1.5.720.tar.gz
* tar xvf l_BaseKit_b_2021.1.5.720.tar.gz
* module load gcc/8.3.0
* in l_BaseKit: ./install.sh --tmp-dir ../tmp
* download FPGA add-on from https://dynamicinstaller.intel.com/oneapi/toolkits/base-kit/linux/ -- "Intel® FPGA Add-on for oneAPI Base Toolkit"
* tar xvf intel-fpga-addon-for-oneapi-base-kit-for-a10gx-linux.zip
* in addon l_intel subdirectory: ./setup.sh --install-dir /.alpha/public/inteloneapi --tmp-dir ../../tmp
The possibly-relevant entries in my environment (from running 'env' as you suggested):
TERM=xterm
SHELL=/bin/bash
QSYS_ROOTDIR=/.alpha/public/inteloneapi/intelfpgadpcpp/2021.1-beta05/QuartusPrimePro/17.1.1/qsys/bin
LD_LIBRARY_PATH=/.alpha/public/opt/gcc-8.3.0/lib64
QUARTUS_ROOTDIR=/.alpha/local/common/pkg/altera/quartus
PATH=/.alpha/public/opt/gcc-8.3.0/bin:/.alpha/lib64/qt-3.3/bin:/.alpha/local/sbin:/.alpha/local/bin:/.alpha/sbin:/.alpha/bin:/sbin:/bin:/bin:/.alpha/bin:/.alpha/X11R6/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin
ALTERA_ROOTDIR=/.alpha/local/common/pkg/altera
_LMFILES_=/.alpha/public/modulefiles/gcc/8.3.0
LOADEDMODULES=gcc/8.3.0
Thanks for any advice!
JSchr20
One additional clue (perhaps) from today. My colleague sent me the following:
In Makefile.fpga I replaced the following line:
   CXX := dpcpp
with:
   CXX := dpcpp --gcc-toolchain=/.alpha/public/opt/gcc-8.3.0
That got rid of the include file complaints, but added the new complaint
 "Error: No recognized input file format on the command line".
Not sure whether it actually fixed the original problem and allowed the process to hit the next problem, or just caused a new problem to occur before the old problem could actually be encountered.
The only reason I have for thinking it's the first rather than the second is that while the commands
   clang -x c -v -E /dev/null
and
   dpcpp -x c -v -E /dev/null
both produce output that includes
   "Selected GCC installation: /.alpha/lib/gcc/x86_64-redhat-linux/4.8.5",
the command
   dpcpp --gcc-toolchain=/.alpha/public/opt/gcc-8.3.0 -x c -v -E /dev/null
produces output that includes:
   "Selected GCC installation: /.alpha/public/opt/gcc-8.3.0/lib/gcc/x86_64-pc-linux-gnu/8.3.0".
Not really sure where to go from here.
JohnT_Intel
Could you try to manually compile the vector add design by using the command "dpcpp -fintelfpga *.cpp"? Please refer to https://software.intel.com/en-us/oneapi-programming-guide-offline-compilation-for-fpga for the command to compile the design.
JohnT_Intel
After further checking, you do not run the "/opt/intel/inteloneapi/setvars.sh" which will setup the environment of your system. You can get more information on the setup fromhttps://software.intel.com/en-us/get-started-with-debugging-dpcpp-linux.
JSchr20
Hi John,
We actually do run setvars.sh, though it is a slightly modified version for our local environment.
We narrowed the problem down to something that gets set when we "export INTELFPGAOCLSDKROOT=/.alpha/local/common/pkg/altera/hld". We obviously can't build a bitfile without that, but we can build the emulation without that variable set, and if we don't set it, the emulations seem to build and run fine.
We have not, however, been able to get past the above error when INTELFPGAOCLSDKROOT is set.
For now, we're giving up. We're going to try to work on the cloud for the time being.
If you or anyone has some further suggestions, we'll happily have a look at this again.
Thank you!
JohnT_Intel
May I know how do you set INTELFPGAOCLSDKROOT?
Could you check if you have "/.alpha/public/inteloneapi/compiler/<oneapi version>/linux/lib/oclfpga" directory? If yes, please set the INTELFPGAOCLSDKROOT to this directory.
