Intel® High Level Design
722 Discussions
I cannot build and run my code for Intel PAC platform in Intel DevCloud.
ArthurRatz
Hi Everyone,
For a few last days long, I'm no longer able to compile and run my code in Intel DevCloud for oneAPI projects.
The attempts to compile and run my code typically end up with the following error message:
I would kindly appreciate for any assistance. Please help me to solve this problem. My DevCloud account id is u39016.
Thanks in advance,
Arthur.
JananiC_Intel
Thanks for reaching out.
You can compile and run the oneAPI samples on FPGA platform in Intel Devcloud.Kindly make sure you use the below commands to compile and run the samples.
build_fpga_emu.sh
source /opt/intel/inteloneapi/setvars.sh
make fpga_emu -f Makefile.fpga
run_fpga_emu.sh
make run_emu -f Makefile.fpga
Try this and let us know the updates.
JananiC_Intel
build_fpga_emu.sh
run_fpga_emu.sh
ArthurRatz
Hi, JananiC_Intel
Yes, exactly it works for me, *BUT* it does *NOT* work when compiling this code for Intel PAC card.
Arthur,
ArthurRatz
Here's what I'm doing:
source /opt/intel/inteloneapi/setvars.sh --force
make run_hw -f Makefile.fpga
ArthurRatz
It normally compiles it with the following commands:
dpcpp -O2 -g -std=c++17 -fintelfpga -c src/simple-add-usm.cpp -o a.o -DFPGA=1
dpcpp -O2 -g -std=c++17 -fintelfpga a.o -o simple-add-usm.fpga -Xshardware
2. Also, I've got a question for you if can I compile my code for Intel PAC card hardware offline (e.g. on-premises) without Intel PAC card installed ?
Could you please guide me how to do that ?
Arthur,
ArthurRatz
I'm sorry to inform you that this didn't work. First I've tried to compile of the samples for Intel PAC board and it finished compilation successfully, *BUT* when I tried to compile my project for Intel PAC hardware, the compilation ended up with the same error:
Error (170143): Final fitting attempt was unsuccessful
Error: An error occurred during routing
Error: Quartus Prime Fitter was unsuccessful. 2 errors, 675 warnings
Error (23031): Evaluation of Tcl script compile_script.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 1 error, 0 warnings
Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful
Error: Compiler Error, not able to generate hardware
clang++: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
Makefile:19: recipe for target 'fpga' failed
make: *** [fpga] Error 1
Looking forward to your reply and the following critical issue resolution.
Arthur,
JananiC_Intel
Thanks for the update.
In Datacenter devcloud we have FPGA emulator and we do not have PAC in it.
Could you let us know which devcloud are you using(Datacenter/FPGA)?
ArthurRatz
Hi, I'm using Intel DevCloud for Intel oneAPI projects. Previously I could compile and run my CL/SYCL program on Intel PAC Platform, but now I experience these difficulties. Also, as I've inspected the following issue, the quartus_fit process crashes when an amount of reserved virtual memory exceeds 16GiB ~ 16384 MB for this process.
Looking forward for this issue resolution as soon as possible :)
Arthur,
JananiC_Intel
As your issue is related to FPGA , we are moving your case to FPGA forum for quicker response.
Dr_FPGA
Hi Janani,
Now I am really confused. I thought this is THE FPGA FORUM for High Level Design. Please stop this practice of bouncing forum threads. Other users are interested in the solutions to the questions,
Just my 2c worth.
JohnT_Intel
May I know if you are able to share with me your source code so that I can debug it to see if it is related to the design not able to fit into the FPGA or due to the system memory issue?
Mickleman
I have the same problem.  Have you found a solution yet Arthur?  The solution suggested above by Janani only applies to the emulator.
Marcus
