Intel® High Level Design
722 Discussions
Intel FPGA SDK for OpenCL : how to generate an aocx file by the output of the OpenCL parser?
caron
I want to modifying the Verilog code in the output of the OpenCL parser. Which is generated by the command "aoc -c -g device/vector_add.cl". And then I want to generate .aocx file from the folder. Anyone know how to do that ?
thank you !!
FawazJ_Altera
Hello, You can do that, however, this might change the functionality of the design. Furthermore, it might bring some timing issues which will increase the design complexity. Thanks
