Intel® High Level Design
606 Discussions
Intel Hls:- error when trying to run the example platform_designer_2xclock
Gopikrishnan
I'm just starting with hls and was trying to run an example design
I got an error when I tried to  make the platform_designer_2xclock example design
I've attached the  error I got.
Please take a look
SyafieqS
Hi Nair,
You may need to refer to link below another forum with same issue
https://community.intel.com/t5/Intel-FPGA-Software-Installation/I-m-unable-to-run-the-counter-example-on-the-FPGA-I-m-running/m-p/701858
Also, please make sure you follow the correct  setup thoroughly the Getting started guide for HLS
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
