Intel® High Level Design
722 Discussions
Issues when running ONEAPI devcloud FPGA Hardwares
Wei-Chih
Hello Intel ONEAPI devcloud
I meet some issues when i run my code on devcloud jupyter using fpga hardware. (follow this website tutorial:  https://devcloud.intel.com/oneapi/documentation/base-toolkit/)
I can run my code by using GPU and FPGA emulator but when I tried to run FPGA hardware node it will get errors as below:
for arria10 error :
terminate called after throwing an instance of 'cl::sycl::runtime_error'
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
make: *** [run_fpga_hardware] Aborted
for stratix10 error:
terminate called after throwing an instance of 'cl::sycl::nd_range_error'
what(): Non-uniform work-groups are not supported by the target device -54 (CL_INVALID_WORK_GROUP
Do you know what are the problems and  how can I modify my code?
thanks
KennyTan_Altera
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
