Intel® High Level Design
655 Discussions
Local management Interface for Arria 10 PCIe Hard IP
sgr
I want to configure the Root Port Configuration space register via the Local management interface.
But I am not sure how to enable the LMI interface.
And One more question is the data width of these registers are 32-bit registers but here only 8 bits are allowed in LMI, So how to configure these registers through LMI
So ,Please Get me back as soon as possible
wchiah
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
wchiah
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wincent_Intel
wchiah
For enable the LMI interface you can refer user guide at link below
https://www.intel.com/content/www/us/en/docs/programmable/683647/18-0/lmi-signals.html
May I know you are using AVST or AVMM ?
Wincent_Intel
sgr
It is Avalon Stream Interface
wchiah
Hi Sgr,
Glad that I am sending correct document for you on AVST LMI signal.
Feel free to get back to me if you need any further clarification.
Regards.
Wincent_Intel
wchiah
Hope below picture clarified on how to enabling LMI in AVST, Arria 10
Wincent_Intel
wchiah
Wincent_Intel
sgr
Hi Wincent_Intel,
Thank you for your support.
I am facing one issue while creating the BSP project in Quartus version 21.3, I am not able to create the project.
Would you please guide me on this
wchiah
I saw similar issue happen before, you can check the KnowledgeBased below
You can try the step at link below
https://www.intel.com/content/www/us/en/support/programmable/articles/000090071.html
If your problem still not solve you may try the second method
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/failed-to-execute-wsl-dos2unix-create-this-bsp/m-p/1344838
Hope this answer your question
Wincent_Intel
wchiah
Wincent_Intel
wchiah
I strongly believe my previous reply answered your question.
We do not receive any response from you to the previous answer that I provided.
This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
Wincent_Intel
