Intel® High Level Design
722 Discussions
Manual simulation IP authoring
DorianL
Hi everyone,
I wanted to know if this is possible to simulate manually an IP created by oneAPI and to create our own testbench instead of using the testbench created in the host file. Do I need to call the module in the file kernel_sys.v generated during a make report ? Thank you !
DorianL
aikeu
Hi DorianL,
I think can refer to the simulation topic from this document:
https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2023-2/evaluate-your-kernel-through-simulation.html
Aik Eu
aikeu
Hi DorianL,
I will close the thread if no further question.
Aik Eu
aikeu
Hi DorianL,
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Aik Eu
whitepau_altera
You can simulate oneAPI IP without the co simulation testbench. Please refer to the niosv code sample.
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL_FPGA/ReferenceDesigns/niosv
For smaller testbench it's also possible but you need to compile each of the files listed in the hw.tcl file.
NOTE Make sure you are using Questa FE or Questa FSE, which come with all the altera libraries pre-compiled.
