Intel® High Level Design
723 Discussions
Max7000 replacement with TTL IOs
Grantwt
I am looking for something like the max7000 FPGA's that has TTL (5v) input / outputs levels on all pins, as I will be interfacing with analog device and TTL logic. I have had too many issues with other FPGA's, that do not have the protection input diodes, I also need access PLL's within the device and standard logic blocks.
I am currently using the EPM7064 devices, and looking some to upgrade to that is of the same type, it seems that protection input diodes are not that common these days.
AminT_Intel
Thank you for choosing Intel for your FPGA designs. You can refer to our catalogue for more details that will fit your design from this link.
Grantwt
Too much information, how about a simple search system where I can enter my key requirements.
AminT_Intel
Sorry we do not have that search system
