Intel® High Level Design
722 Discussions
Memory error when trying to simulate matrix multiplication using HLS math lib
Gopikrishnan
component void test(ihc::stream_in<int> &matrixData,ihc::stream_in<int> &matrixData2,ihc::stream_out<int> &matrixout,bool ld,
        int dim_in,int dim_out){
     ////////////input and output matrix definition/////////
     hls_memory hls_singlepump  hls_max_replicates(1hls_bankwidth(sizeof(int))
     int feat_matrix[N_FEAT][N_COLS_1];
     static int weight_matrix[N_COLS_1][N_COLS_2];
     int out_feat[N_FEAT][N_COLS_2];
     //////////populate the feature and weight matrix//////////
     for (int i=0; i <N_FEAT ; i++){
       for(int j=0 ; j<N_COLS_1 ; j++){
          feat_matrix[i][j] = matrixData.read();
     if (ld){
     for (int i=0; i <N_COLS_1 ; i++){
       for(int j=0 ; j<N_COLS_2 ; j++){
          bool success = false;
          weight_matrix[i][j] = matrixData2.tryRead(success);
   ////////MAT MUL AND WRITE BACK TO STREAM/////////////
     matrix_multiply<int,N_FEAT,N_COLS_1,N_COLS_2,N_DSP,N_DSP>(feat_matrix,weight_matrix,out_feat);
       for(int j=0 ; j<dim_out ; j++){
         matrixout.write(out_feat[i][j]);
When I'm trying to simulate this matrix multiplication for large dimensions it's giving me mem error
Fatal vsim4 memory allocation failure.
I figured out it's the loop unrolling that it's causing the issue. When I try to simulate the code using simple for loops with no unrolling it works fine. Is there any work around this or is there a better way of coding this
BoonBengT_Altera
Hi @Gopikrishnan,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Would recommend to try on the loop unroll pragma, which should reduces the latencey.
More information can be found here on the code snippet and implementation.
Please do let us know if that helps.
Note: there are also details steps on the loops best practices here which are recommended, hopefully it will give some insights.
Best Wishes
BB
BoonBengT_Altera
Hi @Gopikrishnan,
Greetings, as we do not receive any further clarification on what is provided. Hence thread will now be transitioned to community support and we will no longer monitor this thread. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
