I'm trying to use a multikernel design and sending data through channels. However, I keep getting this error when trying to emulate my design:
host: acl_emulator.cpp:309: void* __acl_emulator_channel_dequeue(size_t): Assertion `!__acl_emulator_channel_empty(ch)' failed.
I can't find this "acl_emulator.cpp" archive anywhere. What am I probably doing wrong?
That is an internal compiler error. If you can post your kernel code, it would be easier to find the issue.
#include "../header/stencil.h"
#define CHANNEL_SIZE 16
// Enable channels
#pragma OPENCL EXTENSION cl_intel_channels : enable
// Floating point optimizations
#pragma clang fp contract(fast)
#pragma clang fp reassoc(on)
*********************** DATA TYPES *************************
typedef struct {
float data[ACCESS_SIZE];
} channelData;
************************ CHANNELS **************************
* Arguments
channel float3 fargs[TIME + 1] __attribute__((depth(0)));
* Matrices
channel channelData prev[TIME + 1] __attribute__((depth(CHANNEL_SIZE)));
channel channelData next[TIME + 1] __attribute__((depth(CHANNEL_SIZE)));
channel channelData vel[TIME + 1] __attribute__((depth(CHANNEL_SIZE)));
********************* CONSTANTS KERNEL *********************
__attribute__((max_global_work_dim(0)))
__kernel void constants(const float div_dxSquared, const float div_dzSquared, const float dtSquared) {
* Transform constants into OpenCL's data struct
// Output constants
float3 fconstants_out = (float3)(div_dxSquared, div_dzSquared, dtSquared);
// Inputs contants
float3 fconstants_in;
* Communication with channels
// Writes on channels
write_channel_intel(fargs[0], fconstants_out);
mem_fence(CLK_CHANNEL_MEM_FENCE);
// Reads from channels
* In order to prevent compiler from inferring depth channels with constant's channels,
* the code needs to create a false cycle of channels
fconstants_in = read_channel_intel(fargs[TIME]);
********************** READER KERNEL ***********************
__kernel void reader(__global volatile float* restrict prev_base,
__global volatile float* restrict next_base,
__constant float* restrict vel_squared) {
* Variables to calculate index in grid
uint group_offset = get_local_id(0) * ACCESS_SIZE;
uint x_offset = group_offset - 1;
uint y = get_global_id(1);
uint x_limit = ACCESS_SIZE + ORDER;
* Variable to send to PE
channelData input;
for (uint i = 0; i < ACCESS_SIZE; i++) input.data[i] = 0.0f;
* Sends data to PE
for (uint i = 0; i < x_limit; i++) {
uint real_x = x_offset + i;
uint index = y * NX + real_x;
if (real_x >= 0 && real_x < NX) {
input.data[i] = prev_base[index];
write_channel_intel(prev[0], input);
********************** WRITER KERNEL ***********************
__kernel void writer(__global volatile float* restrict next_base) {
* Reads from PE
channelData output = read_channel_intel(prev[TIME]);
* Writes matrix
next_base[index] = output.data[i];
******************* PROCESSING ELEMENTS ********************
__attribute__((autorun))
__attribute__((num_compute_units(TIME, 1, 1)))
__kernel void PE() {
* Gets current and next PE
const uint id = get_compute_id(0);
const uint next_id = id + 1;
* Reads arguments
const float3 fconstants = read_channel_intel(fargs[id]);
* Writes arguments on next channel
write_channel_intel(fargs[next_id], fconstants);
* Memory Allocation
// Shift registers
__local float __attribute__((doublepump,
memory("MLAB"),
bankwidth(4))) sr_prev[SR_SIZE],
sr_next[SR_SIZE],
sr_vel[SR_SIZE];
const float div_dxSquared = fconstants.s0;
const float div_dzSquared = fconstants.s1;
const float dtSquared = fconstants.s2;
// Channel communication
channelData input;
channelData output;
// Times channel will be read
const uint count = 2 * GROUPS + 1;
* Computation
// Index of shift registers
uint index = 0;
for (uint i = 0; i < count; i++) {
input = read_channel_intel(prev[id]);
for (uint pos = 0; pos < ACCESS_SIZE; pos++)
sr_prev[index++] = input.data[pos];
for (uint i = 0; i < GROUPS * NZ - count; i++) {
for (uint group = 0; group < GROUPS; group++) {}
// Writes future discarded values in channels
output.data[pos] = sr_prev[pos];
write_channel_intel(prev[next_id], output);
// Shifts registers
#pragma unroll
for (uint pos = 0; pos < SR_LIMIT; pos++) {
uint shift_pos = ACCESS_SIZE + pos;
sr_prev[pos] = sr_prev[shift_pos];
// Read from channels
for (uint pos = SR_LIMIT; pos < SR_SIZE; pos++)
sr_prev[pos] = input.data[pos - SR_LIMIT];
Hi ,
Thank you for contacting Intel Support.
Can you try the example mentioned in the below link and check whether same error happens.
https://www.intel.com/content/www/us/en/programmable/customertraining/OLT/OpenCLChannels/lab.pdf
Thanks and Regards
Anil
