Intel® High Level Design
716 Discussions
URGENT Customer failure analysis request MPN 10AX115N4F40E3VGAB , ADV-5050535001 ,11pcs
Ionela
Please support with this issue.
Component information:
Part Number
ADV-5050535001
Description
IC LOGP FBGA1517 10AX115N4F40E
Manufacturer
ALTERA
MPN
10AX115N4F40E3VGAB
QTY
11 pcs
Serial Number
FE05325; FE05312; FE05326; FE053B8; FE052FD; FE05406; FE0581A; FE05816; FE05819; FE05824; FE05818; FE05812; FE05813; FE0582C; FE05817.
DC
2031, 2037, 2125, 2113
Problem analysis:
  • These units failed Base Component Test – Verify BIST on clock devices 0,4, 5, 6 and 7 due to faulty BGA’s.
  • Prior to BGA replacement, all cards were sent to x-ray inspection and there were no soldering issues found.
  • Each BGA received a 7 digit code in order to trace them after re-balling.
  • All faulty BGA’s were re-balled and placed on different units, but the defect was the same.
  • After BGA replacement, the units passed all tests.
  • ADVA R&D’s response regarding this matter is that the failing FPGAs have defective transceivers working marginally.
Test result:
                               Failed Base Component Test - Verify BIST: Clock DEV
Error message:
BGA Marking
SN of failed unit
Error message
Min
MAX
Test result
FE052FD
FA72204102115
Verify BIST: CLOCK DEV 5
PASS
PASS
FAIL
FA72204801152
PASS
PASS
FAIL
FE05406
FA72205200135
Verify BIST: CLOCK DEV 6
PASS
PASS
FAIL
FA72212703919
PASS
PASS
FAIL
FE0581A
FA72213801459
Verify BIST: CLOCK DEV 0
PASS
PASS
FAIL
FE05816
FA72213300463
PASS
PASS
FAIL
FE05819
FA72214404421
PASS
PASS
FAIL
FE05824
FA72214604312
Verify BIST: CLOCK DEV 4
PASS
PASS
FAIL
FE05818
FA72212804851
PASS
PASS
FAIL
FE05812
FA72214602031
PASS
PASS
FAIL
FE05813
FA72214508077
Verify BIST: CLOCK DEV 7
PASS
PASS
FAIL
FE0582C
FA72214406658
PASS
PASS
FAIL
FE05817
FA72213801436
PASS
PASS
FAIL
Ionela
Zawani_M_Intel
Dear Ionela,
Thank you for using Intel FPGA Community Forum.
The case will be continued support via private email.
Thanks!
Wani
