Intel® High Level Design
722 Discussions
Why I am getting this error (error while loading shared libraries: libaltera_a10_ref_mmd.so: cannot open shared object file: No such file or directory) while running OpenCL diagnostics?
RAlbe4
Hello support.
I need to run the board diagnostics after installing my Arria 10 GX board.
However, I got this error
Is there anything missing?
this is an urgent issue please help..
FawazJ_Altera
it seems you have some issues with the PATH environment. I will help you until you get rid of this issue.
Kindly ensure that you have set the PATH environment variable correctly. It can be something like this:
export PATH=$PATH:$INTELFPGAOCLSDKROOT/bin:$QUARTUS_DIR/bin
Please let me know if this could help you.
Thank you.
FawazJ_Altera
Thank you.
RAlbe4
Hello Fjumaah,
Thank you very much for your support. Your answer helped me to fix the issue out.
You saved my day ...
