Intel® High Level Design
722 Discussions
aoc error for emulation
Kulkarni__Vinay
   I installed opencl intel fpga sdk 19.2 and after installation the hello world example seems to compile smoothly taking default board as Arria10GX. But when i try giving the emulator compilation, i get following error:
My Machine spec:
Xeon-16 cores,32 GB RAM and Ubuntu 18.04.
 aoc -march=emulator  -fast-emulator -v device/hello_world.cl -o bin/hello_world.aocx
Warning: Command has been deprecated. The Fast Emulator is the default emulator; use -legacy-emulator if you wish to target the Legacy Emulator.
Error: aoc: The Intel(R) Kernel Builder for OpenCL(TM) compiler (ioc64) can not be found
Any idea on how i can fix this.
Sergey_I_Intel1
Vinay,
Please, check that you set the environment variable CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=<number_of_devices>.
For more information about emulating OpenCL Kernels read here.
Sergey
Kulkarni__Vinay
Hello Intel Folks,
     May i request you to please suggest solution for me. I need emulator urgently for my development.
Sergey_I_Intel1
Hello Vinay,
Sorry for delay in answer.
In previous version of aoc you should use "-march=emulator and -fast-emulator".
In 19.2 version, please, use "-march=emulator -legacy-emulator".
I guess, documentation of aoc was not updated to 19.2.
Sergey
Kulkarni__Vinay
Thanks Sergey for your help.
Now i am able to compile, but running gives error as below:
ERROR: CL_DEVICE_NOT_FOUND
Query for number of devices failed
Please let me know how i can get this working.
My Runs are as below :
(base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ aoc -march=emulator -legacy-emulator -board=a10gx  device/hello_world.cl -o bin/hello_world.aocx
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Linking Object files....
aoc: Compiling for Emulation ....
------------------------------Make of hello world --------------------------------------------------------------------------------------
(base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ make
../common/src/AOCLUtils/opencl.cpp: In function ‘_cl_program* aocl_utils::createProgramFromBinary(cl_context, const char*, _cl_device_id* const*, unsigned int)’:
../common/src/AOCLUtils/opencl.cpp:388:22: warning: ignoring attributes on template argument ‘cl_int {aka int}’ [-Wignored-attributes]
   scoped_array<cl_int> binary_status(num_devices);
------------------------------Running hello world ---------------------------------------------------------------------
(base) wc@ign:~/Documents/opencl_fpga/exm_opencl_hello_world_x64_linux/hello_world$ bin/host
Querying platform for info:
CL_PLATFORM_NAME                         = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR                       = Intel(R) Corporation
CL_PLATFORM_VERSION                      = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
Sergey_I_Intel1
Vinay,
Sergey
Kulkarni__Vinay
Thanks Sergey, it really helped.
HMaha5
Hi Sergey,
       I work in Vinay's team. I was trying out the Sobel Filter Design Example. While compiling the host code I got this error
host/src/display.cpp:23:10: fatal error: SDL2/SDL.h: No such file or directory
 #include <SDL2/SDL.h>
compilation terminated.
Makefile:74: recipe for target 'bin/host' failed
make: *** [bin/host] Error 1
Please help me to solve this.
Thanks and regards,
Hamsika.
PVeli
Use this library in ur path.It will work
cheers,
Prithvi (ISRO)
Dmitry_V_Intel
Hi Hamsika,
Sorry for delay.
Could you please check that you have libsdl2-dev on your machine?
If not, you can install it by executing this command:
sudo apt-get install libsdl2-dev
