Hello all,
I'm new for this platform, My requirement is need to test all the example driver in cyclone 10GX NIOS 2 FPGA "10CX105YF672I5G" part number.
I'm not able to find the example project to test the driver.
Please if someone knows or having the driver kindly share it with me.
Anujayan
Could you please be more specific what you want? Do you mean you want to test NIOS II drivers like this? link : https://www.intel.com/content/www/us/en/docs/programmable/683146/current/guidelines-for-developing-a-nios-ii.html
regards,
Farabi
Hi
I need example codes for testing the drivers, using Intel Quartus Prime pro & Eclipse IDE.
Anujayan
Could you please answer my question so we can assign to the correct Application Engineer to support you?
regards,
Farabi
Hi @user_aj,
Noted on the information shared, we are looking into the request and get back to you with the relevant information as soon as possible.
Thank you for your patients.
BB
Are you using custom board or development board?
thank you.
As of now I am using development board.
which driver do you want test?
All basic supporting drivers.
you can find out all example projects here. pls go through it
thank you.
Thank you for your response.
Can i close the case? if you don't have any queries.
Yes, I will let you know if I need any help in future.
