Intel® High Level Design
722 Discussions
'make fpga_sim' Errors in Getting Started with oneAPI
uniqueMR
I'm getting started with oneAPI following oneAPI samples for FPGAs, and run into errors when 'make fpga_sim':
The referred lines of the makefile are:
These are the steps I followed:
* git clone https://github.com/oneapi-src/oneAPI-samples.git
* cd ./oneAPI-samples/DirectProgramming/C++SYCL_FPGA/Tutorials/GettingStarted/fpga_compile
* mkdir build
* cd build
* cmake .. -DFPGA_DEVICE=Agilex7 -DPART=2
* make fpga_emu (succeed)
* make report (succeed)
* make fpga_sim (failed)
Does anyone have a clue? Thanks
Best,
Runlong
whitepau_altera
Hi Runlong.
What does it say in the vector_add_fpga_sim.log file?
Did you make sure to install the correct Quartus device files? This error often occurs if you didn't download the FPGA device files; there will be a note about missing Agilex™ 7 Device files in the log file.
You can download the Agilex™ 7 device support from the FPGA Software Download Center:
https://www.intel.com/content/www/us/en/software-kit/826843/intel-quartus-prime-pro-edition-design-software-version-24-2-for-linux.html
Look under 'Individual Files' and select the Agilex™ 7 Device support files:
uniqueMR
Hi  whitepau,
I checked the vector_add_fpga_sim.log file, and it reports some license issue. I've already configured the LM_LICENSE_FILE variable but without the other two (SALT_LICENSE_SERVER and MGLS_LICENSE_FILE). With my LM_LICENSE_FILE, I have full access to Quartus Prime Pro 24.1 with Agilex 7 device support. What should I do with the other two to support oneAPI workflow?
I also checked my Quartus device files and found that both Agilex 7 device support and  Agilex common files had been installed.
Do you have any other clues on resolving this issue? Thanks a lot.
Runlong
whitepau_altera
Thanks for sharing the log file.
That appears to be a questa license issue. We have documentation here on how to get a 0-cost Starter Edition license: https://www.intel.com/content/www/us/en/docs/programmable/683472/24-2/and-software-license.html
We are working on getting the installer to handle the questa license for you in the future.
uniqueMR
Hi whitepau,
I've generated the license for questa starter edition and configured the environmental variable in my ~/.bashrc, but it still reports the same issue:
Below is how I configure the license file in ~/.bashrc:
and also the content of my license file to make sure I get the proper one:
I attach my current sim report to this thread. Are there any clues on further resolving this issue? Thanks a lot.
Runlong
whitepau_altera
Are you able to launch questa from the command line? (i.e. using the vsim command)
Can you check your $PATH environment variable? I see that you installed both Questa FPGA edition and Questa FPGA Starter edition; if Questa FPGA edition (which is a paid tool) appears first in your $PATH, then the compiler will try to use it to generate your co-simulation EXE and then fail on license checkout, because the free license is only for Questa FPGA Starter Edition.
uniqueMR
Hi whitepau,
The issue has been resolved. I uninstalled the FPGA edition and only reserved the starter edition, and then it worked. Thanks a lot!
Best,
Runlong
