Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
AVX alignment requirement
TimP
Public statements imply no special alignment requirements for AVX, and that there will be no particular support for more than the 16-byte alignments supported in 64-bit OS. However, the vmovaps instruction requires 32-byte alignment, even though documents indicate there may be no significant advantage in using it. To avoid breaking applications where VECTOR ALIGNED directives/pragmas are used with Intel compilers, those directives would have to continue to require only 16-byte alignment.
Mark_B_Intel1
Hi Tim18,
You are correct, 16-byte alignment is all that can be guaranteed in some contexts, although going forwardcompilers are encouraged to support 32-bit alignments where possible. There are significant performance advantages to being 32-byte aligned if you have 32-byte loads and stores, even for instructions that do not require alignment to behave correctly.
I won't advise anyone to use VMOVDQA ymm flavors - they #GP if not aligned: I have been burned too many times by this in production code. You may want to use them for checking alignment as a debug tool, but in shipping code it would be much safer to use VMOVDQU (or fused load/op) loads and stores.
Mark
