Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
AVX10.2 embedded rounding exception behavior
Beulich__Jan
Exception information has "EVEX.b encoding #UD conditions not met" in the spec, effectively referring back to the SDM. The SDM, however, doesn't even know of EVEX.U yet. This is particularly an issue for scalar insns, where right now one can only guess that EVEX.U clear will #UD when EVEX.b is set. Can this be made explicit, please?
