I am a newbie to AVX512 Intrinsics, I tried this simple test code on Intel Xeon Phi 7210. I compiled using xMIC_AVX512.
I get an illegal instruction. This is the peice of code I am using
__m512d src = _mm512_set1_pd(0.0); //passes successfully
__m256i zerosInt = _mm256_set1_epi32(0);//passes successfully
__m256i vIndex = _mm256_set1_epi32(-1);//passes successfully
int start = 0 int end = 16; int j; __m512d result_vector = _mm512_set1_pd(0.0); //passes successfully int rem = end - j; __mmask8 m = (rem > 8 ? 0xff : (0xff >> (8 - rem))); //passes successfully
printf("passed 3 mask = %d\n", m); __m512d valuesVector = _mm512_mask_loadu_pd (src, m, &values[0]); //passes successfully
printf("passed 4\n"); //This instruction fails :Illegal Instruction __m256i columnsVector = _mm256_mask_loadu_epi32 (zerosInt, m, &columns[0]); //FAILS !! printf("passed 5\n");
Please help,
- Tags:
- Intel® Advanced Vector Extensions (Intel® AVX)
- Intel® Streaming SIMD Extensions
- Parallel Computing
_mm256_mask_loadu_epi32 generates vmovdqu32 instruction from AVX-512VL instruction set, which I don't think is supported in Xeon Phi Knights Landing.
Also I tried to use this one :
__m512d xVector = _mm512_mask_i32gather_pd (src, m, columnsVectorMinusOne, &x[0], 1); And I get the same error (Illegal instruction on KNL 64-Core). This function belongs to AVX512F and generates vgatherdpd.
the error is "Illegal instruction"
I tried this code on KNL 64-Core
Topic Options
