Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1146 Discussions
CPU Serial Enable Support on Intel Processor
asj_anuroop
As per the intel documents the CPU Intel III onwards does contain the CPU Serial number.
I have tried most of the things and on multiple PC's could not able to read the serial
with EAX =3 and CPUID instruction on all PCs the CPUID is disabled ie EAX =1 and CPUID
and the EDX 18 the bit is always "0".
Does any body have any Idea how to enable the cpu serial ?
TimP
Quoting - asj_anuroop
That feature of P-III was not continued in subsequent steppings.
knujohn4
Hi. You can look at this file here: http://developer.intel.com/Assets/PDF/appnote/241618.pdf
Table 2.4 sheet 2 of 3, Note on bit 18, "The Pentium 4 and subsequent processor families do not support this feature."
So only some Pentium IIIs had the PSN support. It was removed I think because of some privacy issues.
Knut
