Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
E8400 with Gigabyte G41M-ES2L Motherboard
g777
I have an E8400 with Gigabyte G41M-ES2L Motherboard I have tried to load window xp (preferred OS)on it and I get a message that there is not enough memory and windows has stopped installation. I then tried to load Windows Vista Home Basic and it worked but then after only 2 - 5 days it would crash and come back up with Windows has encountered a serious error. Then after a day or 2 it would crash and not even come up in Safe Mode. I would then reload Vista and it would repeat the same process. What is wrong? I have downloaded all the Windows Updates.
Another fact is that I had an ECS G31T-M Motherboard and I replaced it with the above board because I thought the board may be bad. The old board would download the XP OS and then all of a sudden the same error described above started to come up when I tried to load XP OS. I have replaced the hard drive also. The only thing left is the Intel processor that I bought only in June 2008.
Please help!
