Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Intel manual has some mistakes
logicman112
Intel 64 and IA-32 Architectures Software Developers Manual
Volume 1: Basic Architecture
Order Number: 253665-034US March 2010
3.7.5.1 Specifying an Offset in 64-Bit Mode
The offset part of a memory address in 64-bit mode can be specified directly as a
static value or through an address computation made up of one or more of the
following components:
Displacement - An 8-bit, 16-bit, or 32-bit value.
Volume 2A: Instruction Set Reference, A-M
Order Number: 253666-034US March 2010
2.2.1.3 Displacement
Addressing in 64-bit mode uses existing 32-bit ModR/M and SIB encodings. The
ModR/M and SIB displacement sizes do not change. They remain 8 bits or 32 bits and
are sign-extended to 64 bits.
In the first manual it says that displacement can be 16 bits in 64-Bit Mode, in the other one it says it is only 8 or32!!
logicman112
3.6 OPERAND-SIZE AND ADDRESS-SIZE ATTRIBUTES
Table 3-4 shows effective operand size and address size (when executing in
protected mode or compatibility mode) depending on the settings of the D flag and
the operand-size and address-size prefixes.
Another mistake!! It is not Table 3-4, it is Table 3-3 actually while the section is explaining operand and address sizes in 32 bits. It is good for lazy documentation people to work hard a little bit!!
