Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SSE4 is there a BigInt LIbrary?
gbrun
i5 2410M processor I suppose can NOT use AVX
but can use SSE4.2
Is there a BigInt Library for SSE?
I Guess I am looking for something that implements unsigned integer
PMULUDQ (with 128-Bit operands)
PMULUDQ __m128i _mm_mul_epu32 ( __m128i a, __m128i b)
and does the carries.
Its a Laptop so I cant buy an NVIDIA GTX 550, which isnt so grand on unsigned Ints, I hear.
Max_L
Intel Core i5 2410M is based on 2nd generation of Intel Core Microarchitecture (according to our marketing that is :), also known as Sandy Bridge) and it does support AVX - http://ark.intel.com/products/52224
However with arbitrary precision arithmetic your best shot is still a general purpose instruction set - to find implementations check crypto libraries, or e.g. crypto component of OpenSSL.
-Max
TimP
I suspected much of what Max said here.
The advantage of a future extended AVX instruction set would be realized only if you have vectorizable code.
styc
Just use GMP and let the experts worry about performance for you.
