Hello: I want to use sde to get region pinball from the whole pinball which is from SPEC2006 473case,but I find a error. Its output is as following:
Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory Freepages: Out of memory ...... I have tested the sde-external-9.14.0-2022-10-25-lin.tar.xz,sde-external-8.69.1-2021-07-18-lin.tar.bz2 and sde-external-9.21.1-2023-04-24-lin.tar.xz, they have the same problem. 473perfwarmup100000length100000.473perfwarmup100000length100000_3349724.pinpoints.in.csv: cluster 323 from slice 75,0,123,87,387,0.00219 473perfwarmup100000length100000.473perfwarmup100000length100000_3349724.0.result: -- start of image-load-log --------------------------------------- Loading /home/zgcc/Pinball/473perfwarmup100000length100000/run/astarperf(0x000400000:0x0004e8017) preloaded_image: 1 1 0x000000000 /home/f/Pinball/473perfwarmup100000length100000/run/astarperf -- end of image-load-log ----------------------------------------- copy_images: 0 inscount: 14298436387 OSTid: 3349724 log_entries: 115156 ended_before_sc: 0 num_logged_true_dependencies (RAW): 0 num_logged_false_dependencies (WAR/WAW): 0 num_signals 0 num_syscalls: 1787 ip_type: init_pc: 0x000401490 ip_type:last_pc: 0x000432986 restore_text_pc: 1 ip_entry:restoretext_pc: 0x00049f318 ip_entry:restoretext_pc: 0x00048c683 ip_entry:restoretext_pc: 0x000435373 ip_entry:restoretext_pc: 0x00048ba99 ip_entry:restoretext_pc: 0x00046c184 ip_entry:restoretext_pc: 0x000441405 ip_entry:restoretext_pc: 0x00048bac4 ip_entry:restoretext_pc: 0x0004896e7 ip_entry:restoretext_pc: 0x00049f3c5 ip_entry:restoretext_pc: 0x00043544a ip_entry:restoretext_pc: 0x000417f76 ip_entry:restoretext_pc: 0x0004a48ba ip_entry:restoretext_pc: 0x00048bbf7 ip_entry:restoretext_pc: 0x00040bfc4 ip_entry:restoretext_pc: 0x00048a4a8 ip_entry:restoretext_pc: 0x000411457 ip_entry:restoretext_pc: 0x00041206f ip_entry:restoretext_pc: 0x0004a19aa ip_entry:restoretext_pc: 0x0004a31c0 ip_entry:restoretext_pc: 0x00048ed83 ip_entry:restoretext_pc: 0x00046c454 ip_entry:restoretext_pc: 0x0004a325a ip_entry:restoretext_pc: 0x0004a1a53 ip_entry:restoretext_pc: 0x0004a1a5c ip_entry:restoretext_pc: 0x0004a1a76 ip_entry:restoretext_pc: 0x0004a1a7e ip_entry:restoretext_pc: 0x00048edf0 ip_entry:restoretext_pc: 0x0004a1ac0 ip_entry:restoretext_pc: 0x00048c9ff ip_entry:restoretext_pc: 0x00043570a ip_entry:restoretext_pc: 0x00048a623 ip_entry:restoretext_pc: 0x000461cca ip_entry:restoretext_pc: 0x0004a1b41 ip_entry:restoretext_pc: 0x0004a1b51 ip_entry:restoretext_pc: 0x00048d74a ip_entry:restoretext_pc: 0x00048d79a ip_entry:restoretext_pc: 0x00048c091 ip_entry:restoretext_pc: 0x00048a89a ip_entry:restoretext_pc: 0x00048909b ip_entry:restoretext_pc: 0x00048a8c2 ip_entry:restoretext_pc: 0x00046d3b6 ip_entry:restoretext_pc: 0x0004a1da4 ip_entry:restoretext_pc: 0x00041491d ip_entry:restoretext_pc: 0x000431ec7 ip_entry:restoretext_pc: 0x000401107 ip_entry:restoretext_pc: 0x00040111f ip_entry:restoretext_pc: 0x000401126 ip_entry:restoretext_pc: 0x00046d545 ip_entry:restoretext_pc: 0x00046bd71 ip_entry:restoretext_pc: 0x0004011b0 ip_entry:restoretext_pc: 0x0004011cf ip_entry:restoretext_pc: 0x00041ab17 ip_entry:restoretext_pc: 0x00041ab1f ip_entry:restoretext_pc: 0x0004404f5 ip_entry:restoretext_pc: 0x00041abb8 ip_entry:restoretext_pc: 0x00048c3e1 ip_entry:restoretext_pc: 0x000410f70 ip_entry:restoretext_pc: 0x00041abdc ip_entry:restoretext_pc: 0x00046bedf ip_entry:restoretext_pc: 0x000484bf2 ip_entry:restoretext_pc: 0x000430970 ip_entry:restoretext_pc: 0x000411123 ip_entry:restoretext_pc: 0x000401490 ip_entry:restoretext_pc: 0x0004014b5 473perfwarmup100000length100000.473perfwarmup100000length100000_3349724.relog.txt: Enabled messages [UnixVersion()] 55 info: Informational messages (enabled by default) Logger finished sanity check Logger first configuration phase completed Region selector activated Pinball basename: whole_program.473perfwarmup100000length100000/473perfwarmup100000length100000.473perfwarmup100000length100000_3349724 Relog set log:fat flag Replaying on 'Linux', recorded on 'Linux' Found VDSO in page 0x7ffedd345000 [0] Pinball basename: /home/jingge/mnt/tools/sde/tmp/473perfwarmup100000length100000.473perfwarmup100000length100000_3349724.pp/473perfwarmup100000length100000.473perfwarmup100000length100000_3349724 Relogging run, will wait for Ok signal from replayer Preloaded images: 1 Setting image replay mode in Pin. [0] Started logging thread OSPid: 49448 OSTid: 49448 [0] Started Replaying thread OSPid: 49448 OSTid: 49448 PIN tid 0 [0] Restoring initial pages Replay preloaded 1 images Replay preloaded image: /home/zgcc/Pinball/473perfwarmup100000length100000/run/astarperf Image index: 0 Loading /home/zgcc/Pinball/473perfwarmup100000length100000/run/astarperf(0x000400000:0x0004e8016) [0] Thread replayer initialized [0] Mapping stack address, pin tid 0 [0] All threads were created, ready to replay [0] Restoring Initial checkpoint before PC:0x000401490 ctxt: 0x14f116f56dc0 [0] Replayer ThreadStart Initial IP: 0x000401490 [0] region-start [0] + RECEIVED AND PROCESSED START event: ip:0x000401437 time:Wed Jun 7 16:37:33 2023 [0] Stopping all threads - processing controller event [0] Stopping all threads succeeded [0] + STARTING NEW REGION at: ip:0x00040144a time:Wed Jun 7 16:37:33 2023 [0] iregion SetRegionName final 14298436386 region_end 387 region id 123 length 300 warm len 0 prolog len 0 epi len 0 slice size 14298436299 start icount 87 [0] Region has 1 existing threads(s) [0] SyncThreads clear pending event [0] Resuming all threads - complied processing controller event [0] InitRegion : 0 [0] region-end [0] + RECEIVED STOP event: icount: 296 time:Wed Jun 7 16:37:33 2023 [0] Stopping all threads - processing controller event [0] Stopping all threads succeeded [0] EndRegion called for pp_id: 0 [0] End of Region at icount: 297 [0] Closing global resources. [0] RemoveVsyscallFromRanges: removed pages: 0 [0] Wrote address ranges: pagecount: 89438. Logged text pages count:89438 Logged data pages count:0 (total logged pages:89438) [0] SUCCESSFULLY CLOSED ALL TRACE FILES AT REGION END. [0] FinishRegion reseting all thread icounts [0] SyncThreads clear pending event [0] Resuming all threads - complied processing controller event [0] Replayer End of thread reached: 14298436386 final count: 14298436386 [0] Wait for all threads to finish [0] Finished replaying thread OSPid: 49448 OSTid: 49448, 14298436386 instructions [0] ThreadFini in Replayer with status 0 [0] ThreadFini: logger thread at 0x14f116f60408 [0] EndRegion called for pp_id: 0 Process exit with status 0 Closing message file 473perfwarmup100000length100000.473perfwarmup100000length100000_3349724_t0r123_warmup0_prolog0_region300_epilog0_123_0-00219.0.result: -- start of image-load-log --------------------------------------- Loading /home/zgcc/Pinball/473perfwarmup100000length100000/run/astarperf(0x000400000:0x0004e8016) preloaded_image: 1 1 0x000000000 0x000000000 0x000000000 0x000000000 /home/zgcc/Pinball/473perfwarmup100000length100000/run/astarperf -- end of image-load-log ----------------------------------------- OSTid: 49448 log_entries: 0 ended_before_sc: 0 num_logged_true_dependencies (RAW): 0 num_logged_false_dependencies (WAR/WAW): 0 num_signals 0 num_syscalls: 0 inscount: 297 ip_type:last_pc: 0x00043544a internal_repcount: 0 internal_last_repcount: 0 ip_type: init_pc: 0x000401633 restore_text_pc: 1 ip_entry:restoretext_pc: 0x000435373 ip_entry:restoretext_pc: 0x000401633 ip_entry:restoretext_pc: 0x00043544a ip_entry:restoretext_pc: 0x000401844 ip_entry:restoretext_pc: 0x000401107 ip_entry:restoretext_pc: 0x00040111f ip_entry:restoretext_pc: 0x000401126 Thank you very much. Jingge 2023.06.07
Sorry for the late reply. We have a newer version of Intel SDE with many bug fixes, please try this one.
Alternatively, please check the SPEC build configuration to see if it is using special memory allocation library. There are cases where such libraries allocate most of the available memory up front and this does not leave enough memory for Intel SDE to work. Please note that generating a pinball consumes a lot of memory.
Thank you for your reply. I have test the new SDE (sde-external-9.24.0-2023-07-13), but it cannot reslove this problem.
Cmd:
/home/jingge/mnt/tools/sde/sde-external-9.24.0-2023-07-13-lin/sde -p -xyzz y -p -reserve_memory -p whole_program.473perfwarmup100000length100000/473perfwarmup100000len gth100000.473perfwarmup100000length100000_3349724.address -replay -xyzzy -replay:deadlock _timeout 0 -replay:basename whole_program.473perfwarmup100000length100000/473perfwarmup1000 00length100000.473perfwarmup100000length100000_3349724 -replay:playout 0 -log:fat -log:al low_deltas 0 -log:allow_repeats 0 -log:allow_cntg_hdr_only 1 -log:allow_reg_deltas 0 -log:al low_reg_repeats 0 -log:allow_size_reuse 0 -log -xyzzy -regions:in 473perfwarmup100000length1 00000.473perfwarmup100000length100000_3349724.pinpoints.in.csv -regions:out 473perfwarmup100 000length100000.473perfwarmup100000length100000_3349724.pinpoints.out.csv -regions:warmup 10 1500 -regions:prolog 0 -regions:epilog 0 -log:basename 473perfwarmup100000length100000.473pe rfwarmup100000length100000_3349724.pp/473perfwarmup100000length100000.473perfwarmup100000len gth100000_3349724 -log:compressed bzip2 -log:focus_thread 0 -log:mt 0 -- /home/jingge/mnt/t ools/sde/sde-external-9.14.0-2022-10-25-lin/intel64/nullapp
Error:
Test environment:
Ubuntu20.04 Intel haswell 32G
My computer has enough memory. Please see the attachment for specific test-related documents.
Thank you very much!
jingge
Pin is using mmap extensively in its memory manager which might cause a huge amount of mmap (of small) regions.
You might hit the kernel limit hence resulting with this error message.
To remedy this problem you need to modify sysctl vm.max_map_count attribute.
This requires root access. You can get more details in this post: https://www.systutorials.com/maximum-number-of-mmaped-ranges-and-how-to-set-it-on-linux/
