Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1134 Discussions
Where can I find documents about SSE3 and SSE4 for early study?
kalven
Where can I find documents about SSE3 and SSE4 for early study, or the website link?
Mark_B_Intel1
Information on SSE4 including some whitepapers is available at www.intel.com/software/avx while SSE3 and SSE4 are both documented in the software developer manuals http://www.intel.com/products/processor/manuals/- I'd recommend you look mainly at volumes 2a and 2b for details of the instructions. Can you speak more of the problem you're trying to solve?
Mark
kalven
Thanks for your information.
Untill now, I am not use SSE3 and SSe4 in my application. I just want to have some knowledge about them. Whem I have further tests of them, maybe I will have some problems to share with you.
srimks
New Contributor II
Quoting - kalven
I would suggest to read "IA-32 Intel Architecture Optimization Reference Manual" to start with. Followed by "Intel Intrinsic Functions Reference" & "Intel C++ Compiler Reference" documents. These documents does have preliminary examples to start writing SSE3 & SSE4 based code.
ganeshsurabi_com
Is there any tutotial.
Like this one for SSE2 which I found with great difficulty www.intel.com/software/products/college/ia32/sse2/sse2down.htm
RG
srimks
New Contributor II
RG
It's very hard to find and address your needs. The Intel Vol-I & II Instructions Manual would take long time for any beginners to conquer it. Would advice follow few things to start with -
- Intel C++ Intrinsic Reference Document
-Intel C++ Compiler for Linux Systems User's Guide (search SSE/SSE2)
- Intel Pentium 4 & Xeon Processor Optimization Manual http://www.cs.grinnell.edu/~walker/courses/211.fa01/pentium-4-optimization.pdf Chapter 3 onwards.
- Refer Apple SIMD/Altivec website http://developer.apple.com/hardwaredrivers/ve/sse.html but don't get confused with SIMD & Altivec way of writing SSE programming.
I think abovefour should be sufficient to guide you in writing small SSE2 examples program and than latter move to Intel Vol-I & II Instructions Manual for better understanding OR try referring in between for any doubts related to definition of any instructions.
Perform google search too if needed apart from above 4 helps.
~BR
