Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
compiling the assembly code
narendhar
I want to compile the instruction sets for 32/64 bit processors.How can i do it? I want to know from the scratch.
Thomas_W_Intel
The Intel 64 and IA-32 Architectures Software Developers Manual Combined Volumes 2 (available here) contains a description of the instruction set.
However, building a compiler is a huge effort and requires much more than just knowing the instruction set. I therefore recommend that you start with reading a book or lecture notes of acompiler class.
SergeyKostrov
Valued Contributor II
levicki
My guess is that he just wants to compile a list of instructions :)
Bernard
Use inline assembly wrapped by the C code.
