Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
give me a hint,
jvava
i read the Manual over and over, but still have not understood the 3.1.1.2 INSTRUCTION COLUMN,
1.
among much type of oprand (rel8, rel16, rel32, ptr16:16, ptr16:32, r8, r16, r32, imm8, imm16, imm32, r/m8, r/m16, r/m32,m,m8,m16,m32,m64,m128,m16:16,m16:32,m16&32,m16&16,m32&32,moffs8,moffs16,moffs32,sreg,m32fp,m64fp,
m80fp,m16int,m32int,m64int,st,st(0),st(i),mm,mm/m32,mm/m64,xmm,xmm/m32,xmm/m64,xmm/m128), Which is from modR/M byte(i dare guess r/m8,r/m16,r/m32, r8, r16, r32 do, and some r8 is from +rb)? and which is from ib(i dare guess imm8 do)....
rel8 is from modR/M or a byte following the opcode byte?
ptr16:16 is from modR/M or a word following the opcode word?
m,m8,m16,m128 is from modR/M or address immediate following the opcode word?
m16:16 is from modR/M or address immediate following the opcode doubleword?
m16&16 is from modR/M or address immediate following the opcode doubleword?
moffs8 is from modR/M or address immediate following the opcode doubleword?
2.
if modR/M byte is 10 000 100, that can been decoded as [-][-] + disp32, further,
if sib byte is 00 000 101, that can been decoded as [EAX] + disp32 + [EBP],
so the result is [EAX] + disp32 + [EBP] + disp32, that means 8 byte is following the sib byte, but the manual says maxiumn of displacement is 4 bytes. so what i decoded is not right. then how to decode this case.
for long time i cant understand these problem, please help me, THANKS.
jimdempseyatthecove
Black Belt
Google search for:
"opcode map" format:.pdf site:intel.com
In the returned list you should find a programmer's reference manual.
Using the ledgend for the op code map (once you understand which 4-bit nibble is which) you will understand better on how the instruction bytes are ordered. In general terms the instruction sequence is:
(optional 0 or more prefix bytes e.g. address override, data override, LOCK, REP, segment,REX, ...)
1 or 2 op code bytes (required)
(optional Mod R/M depending on 1 or 2 byte op code)
(optional SIB depending on Mod R/M byte)
(optional disp nn depending on 1 or 2 byte op code) or (optional disp nn depending on Mod R/M)
(optional imm nn depending on 1 or 2 byte op code)
When a component of the instruction is present, it occupies the position listed above.
You cannot have a SIB without Mod R/M
Jim
jimdempseyatthecove
Black Belt
2.
modR/M of 10 000 100 is [--][--] is Reg operand of EAX with SIB byte follows but there is noothercomponent of theeffective addressin the Mod R/M
SIB of 00 000 101 is scale index register is EAX (no scaling) baseisdsp32[EBP] so effective address is disp32[EBP + EAX]
mov dword ptrdisp32[EBP + EAX],EAX
would fit the addressing mode
There is only one disp32
When you have something like aMOV m32,imm32 you could have
MOV disp32[eax +edx*4],imm32
In which case you would havea displacement followed by an immediate
Jim Dempsey
jvava
thanks a lot.
SHIH_K_Intel
Quoting - jvava
1.
2.
Jvava
When you read section 3.1.1.2 to understand the notation of the instruction column, you need to read section 3.1.1.1 first, which describes the opcode column and the various notations for the opcode column. Section 3.1.1.1will tell you whether there is an ModR/M byte following the opcode byte.
For example, /digit, /r, ib, iw, id, io need the ModR/M byte. When you see FF /3 for far call with the m16:32 notation in the instruction column, the 3-bit r/m field of the modR/M byte encodes an offset address, but this offset address in not the target of the far call, the offset address points to six bytes (16 + 32 bits)of memory which is interpreted as a linear address consisting of a 16-bit selector and a 32-bit offset address. The target address of the far call is this linear address represented by six consecutive bytes in memory.
