Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
intel xe composer compiler with AVX code
semsem_h_
Are there any cases the intel compiler gives worst performance than other compilers especially visualstudio compiler v120. When I compiled a sample of matrix multiplication with intel xe composer 2013 sp1 compiler using inline assembly avx code with visual c 2013 ultimate  the performance of intel compiler is bad than the visual studio compiler 120. Can anyone help me what is the reasons to that?
my machine is intel core i5
Thank you
TimP
I haven't seen a case like that, but there are (usually) small differences in the way the various compilers deal with simd intrinsics. For example, icl may change generated code according to /arch, while gcc may be more influenced by unroll settings. So an actual example, including your preferred settings, should help.
As icl covers many of the important cases of matrix multiplication in the performance libraries, it seems relatively unusual that intensive intrinsics coding would be justified.
semsem_h_
thanks for your replying
i didn't use any libraries i write my own hand code using inline assembly and i surprised that the performance using visual studio compiler is better than icl compiler!
