Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
movq doesn't work, it never move the data
hurricanezhb
I am coding a function using the asembly code and compile it using the MASM. The code is as follows:
mcasm_j_sse2_10bits proc syscall ;u8 *ref_y, u8 *curr_y, s32 ystepz, s32 curr_wh
push_all_x86_reg
mov ebp, esp
sub esp, 32*24+80+4
and esp, 0fffffff0h
mov dword ptr[esp+32*24+80], ebp
mov esi, edx ;back of the curr_y
mov edx, esp
push ebx ;curr_wh
push eax ;ystep
call mcasm_vext_sse2_10bits
mov edx, esi
add esi, 8
mov ecx, esp
mcjpt8_16lopo0:
movq xmm0, mmword ptr[ecx+ 0]
movq xmm1, mmword ptr[ecx+ 32]
movq xmm2, mmword ptr[ecx+32*2]
movq xmm3, mmword ptr[ecx+32*3]
movq xmm4, mmword ptr[ecx+32*4]
movq xmm5, mmword ptr[ecx+32*5]
outputmmy ecx, 32
outputxmmx xmm0
outputxmmx xmm1
outputxmmx xmm2
outputxmmx xmm3
outputxmmx xmm4
The function firstly get a big buffer from the stack, then call the mcasm_vext_sse2_10bits to write the data to the buffer in the stack. Next, the function read the buffer using the movq to xmm register. But I found that the movq failed that the xmm register is zero. I print the data in the buffer ecx and the xmm0-xmm4 register to the screen, the resultsare that thedata in ecx is right,butxmm0-xmm4 are all zero, the movq failed.
The macro outputxmmx is to print the data in the xmm register.
The macro outputmmy x,y is to print the buffer data to screen, it is defined as follows:
outputmmy macro xxx, yyy
push eax
push edx
push ecx
lea ecx, [xxx]
mov edx, yyy
call @printmemory@8
pop ecx
pop edx
pop eax
endm
The @printmemory@8 is defined in a .cpp file as follows:
extern "C" __declspec(noinline) void FstCllCvsn printmemory(s16 *psrc, int len)
printf("srcaddr: %10x len %6d\\n", psrc, len);
for(int i=0;i
printf("%8x ", psrc);
if(i%8==7)
printf("\\n");
neni
New Contributor II
can you post outputmmx macro?
keep in mind that xmm registers xmm0-xmm5 are not volatile and their value might change in your function call to printf
hurricanezhb
I find more strange thing. When the asm code access the stack, some other xmm registers are set to zero automatically. For example,
outputxmmx xmm5
outputxmmx xmm6
pmaddwd xmm1, xmmword ptr[eax+16] ;mul (1,-5)
outputxmmx xmm5
The xmm5 is 0x25660000eb650000c3ec0000f8660000 originally, but after the instruction " pmaddwd xmm1, xmmword ptr[eax+16] ;mul (1,-5)", it becomes zero. The eax pointer to a memory in stack.
neni
New Contributor II
hurricanezhb
EXTRN ?print128u8@@YAXT__m128i@@@Z:PROC
outputxmmx macro xx
sub esp, 16
movdqu [esp], xmm0
push eax
push ecx
push edx
movdqa xmm0, xx
call ?print128u8@@YAXT__m128i@@@Z
pop edx
pop ecx
pop eax
movdqu xmm0, [esp]
add esp, 16
endm
The ?print128u8@@YAXT__m128i@@@Z is defined in a .cpp file as follows:
void print128u8(__m128i p)
u16 ds[8];
u8 *pp=(u8*)ds;
_mm_storeu_si128((__m128i*)ds, p);
for(int i=0;i<16;i++)
printf(" %4x", pp);
printf("\n");
