Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
where can i find the whole instruction set of sandybridge?
Lin_W_1
Hi
      I got a "invalid opcode" exception when I used "invd" instruction to invalidate all the caches without flushing cache data to memory on Sandybridge.
      I doubt that when "invd" is supported on Sandybridge, where can I find a spec of the whole instructions set of sandybridge?
      or anyone has the similiar exprience as me, and could give me some help and suggestions?
Thanks very much
Bernard
Valued Contributor I
Please consult Intel processor manuals.
Thomas_W_Intel
The Intel® 64 and IA-32 Architectures Software Developer Manuals can be found here: http://www.intel.de/content/www/us/en/processors/architectures-software-developer-manuals.html The instruction set reference is in Volume 2. "invd" is supported from Intel486 onwards. However, it is a privileged instruction. Maybe this is the issue that you are running into.
Bernard
Lin W. wrote:
Hi
Thanks very much
Is your code compiled and used as a WDM kernel mode driver?
