I'm trying to use function ippiFFTFwd_RToPack_8u32s_C3RSfs. The input is 512x512 RGB image. When I perfom forward and then inverse FFT, the image is either very dark or completly white, depending on the normalization I use.
For example, if I use any normalization other than IPP_FFT_NODIV_BY_ANY, resulting image will be very dark. If I use IPP_FFT_NODIV_BY_ANY, then I must specify 17 as a scale factor in the inverse FFT, otherwise the image is completly white.
Documentation is very vague about this (and many other) issues. I would assume that I don't need a scale factor (scale factor=1) to do froward and then inverse FFT to get the original image. Is this due to integer nature of this specific fft? Cananyone shed some light on this?
Miro
Hi Miro,
reqarding our expert, some small difference is allowable when you specify IPP_FFT_DIV_BY_SQRTNor IPP_FFT_DIV_INV_BY_N flags in call of ippiFFTFwd_RToPack_8u32s_C3RSfs / ippiFFTInv_PackToR_32s8u_C3RSfs functions.
When you use IPP_FFT_NODIV_BY_ANY flag for images 512x512 you need to calculate scaleFactor as scaleFactor=18. Because of9+9 (512=2^9), in this case you also should get close results.
If you still have big differences please check if you call IPPfunctions with correct parameters.
Vladimir
Vladimir,
thank you very much. I didn't realize that scaling factor is actually a power of two. Documentation doesn't mention that (did I miss it?)
Miro
