64-bit IPP Mac OS X
John_Pauley
All,
I've installed IPP on Mac OS X 10.6.2 (Mac Pro) via the C++ Compiler Pro install but do not see the 64-bit IPP libraries (static or dynamic) and no explicit option to install them. Any suggestions?
John
Vladimir_Dudnik
MacOS use so called 'FAT' libraries. Single binary which can run in both 32-bit and 64-bit mode (detected at run time).
Vladimir
John_Pauley
Seems obvious now that you mention it:) Issue was in Makefile that is common among Mac and Linux where Linux has different filenames for the libraries. Thanks for your support.
John
Vladimir
