7.0.7.325 ippResizeSqrPixel crash with CUBIC interpolation
Aris_Basic
is there a know bug with Resize and CUBIC interpolation ?
on certain images (i assume specific sizes cause it, but nothing huge or something like that (960x721) )
both ReiszeSqlPixel and Resize (8u_C1R) crash with illegal memmory access.
im using CIpl wrappers from ipp-samples 7.0.7.064 but did try to modify ownResize8u_Plane to use ippiResizeSqrPixel once i noticed crash with ippiResize, however result is the same.
Thomas_Jensen1
As you might understand, without a simple test project, in which your problem is reproducable, nobody here can help you.
I use those functions and it did not crash yet.
To my knowledge, most crashes stem from improper use of the "step". Step is a parameter to most IPP functions. It must be a value in bytes that move a pointer of a pixel to the pixel below it.
SergeyKostrov
Valued Contributor II
>>...is there a know bug with Resize and CUBIC interpolation ? Aris, If you have an ippiDemo.exe for your version of IPP library use it for a verification. I didn't have a chance to verify it but this is what I would try first. Also, there are source codes for ippiDemo.exe and take a look at it as well. >>...on certain images (i assume specific sizes cause it, but nothing huge or something like that (960x721) )... Thomas's point is absolutely right and more technical details ( a test case, please ) will help ( it is in your interest to provide it ).
