is there a know bug with Resize and CUBIC interpolation ?
on certain images (i assume specific sizes cause it, but nothing huge or something like that (960x721) )
both ReiszeSqlPixel and Resize (8u_C1R) crash with illegal memmory access.
im using CIpl wrappers from ipp-samples 7.0.7.064 but did try to modify ownResize8u_Plane to use ippiResizeSqrPixel once i noticed crash with ippiResize, however result is the same.
As you might understand, without a simple test project, in which your problem is reproducable, nobody here can help you.
I use those functions and it did not crash yet.
To my knowledge, most crashes stem from improper use of the "step". Step is a parameter to most IPP functions. It must be a value in bytes that move a pointer of a pixel to the pixel below it.
