8 bit grayscale mjpeg decode problem
ynhuang
Hi
I use ipp 5.3 towrite a program to dispaly stream from ip camera. I use UMC jpeg decoder to decode mjpeg stream.
It works well until decode8 bit grayscalemjpeg. The image incorrect and sometime UMC jpeg decoder crash.
Does anyone knows ipp and UMC 5.3 support 8 bit grayscalemjpeg ? Or how to fix this problem ?
Sergey_Ryadno
Quoting - ynhuang
Hi
Hi, can you attach here this 8 bit grayscale mjpeg file? It will be very helpful to us in invistigating this issue.
ynhuang
Quoting - sryadno
Hi sryadno,
grayscale.zip is the mjpeg file that I use.
Sergey_Ryadno
Quoting - ynhuang
Hi
Hi, try to change incodecjpegsrcjpegdec.cpp in function ColorConvert() in case "Gray to BGR"
this strings
pSrc8u[0] = m_ccomp[0].GetCCBufferPtr(thread_id);
pSrc8u[1] = m_ccomp[2].GetCCBufferPtr(thread_id);
pSrc8u[2] = m_ccomp[2].GetCCBufferPtr(thread_id);
to this
pSrc8u[1] = m_ccomp[0].GetCCBufferPtr(thread_id);
pSrc8u[2] = m_ccomp[0].GetCCBufferPtr(thread_id);
I think it mast fix this issue.
Sergey_Ryadno
Quoting - sryadno
this strings
to this
Applying of this changes lead to correct show attached mjpeg file in umc simple_player.
ynhuang
Quoting - sryadno
Thanks a lot. I can dispaly this video correct now
