AAC Encoder parameters needed
bitsmaker
I am successfully initializing the AACEncoder with the following parameters:
UMC::AudioCodecParams audioCodecParams;
audioCodecParams.m_info_in.channels = 1;
audioCodecParams.m_info_in.sample_frequency = 16000;
audioCodecParams.m_info_out.bitrate = 32000;
audioCodecParams.m_info_out.stream_type = UMC::AAC_MPEG4_STREAM;
audioCodecParams.profile = UMC::AAC_LC_PROFILE;
audioCodecParams.m_pData = spMediaData.get(); // m_pData points to array containing 0x1408
On the decoder side I set the following initialization parameters
audioCodecParams.m_info_in.stream_type = UMC::AAC_MPEG4_STREAM;
When I call GetFrame on the decoder side I get a result value of UMC_OK
m_spAACDecoder->GetFrame(&m_mediaInputData, &m_mediaOutputDataVec[m_outputIndex]); // returns UMC_OK
However when calling
dataOutSize = m_mediaOutputDataVec[m_outputIndex].GetDataSize();
dataOutSize has a value of 0;
Can someone please help me figure out what the right Encoder parameters are so that I can use the aforementioned AAC Decoder parameters.
I have verified that the AAC decode parameters do work with other sources.
Chao_Y_Intel
You may help to provide some runable to code to have some further check? For the encoder output, what is size of the output? is it only has 2 byte, '0x1408'? This looks like audio header, anther then the real audio frame data.
Chao
bitsmaker
Thanks but If figured out my answer.
