About IPP and openCV
j3r3mi
First of all, sorry if i posted on the wrong forum. I'm working on KLT atm. Currently my whole application is based on openCV 2.0.
I saw on openCV 1.0 cvCalcOpticalFlowPyrLK that a IPPI_CALL( icvCalcOpticalFlowPyrLK_8uC1R ..... ) was being called. IsicvCalcOpticalFlowPyrLK_8uC1R a IPP API??
are those APIs with icv prefix from IPP??
Currently i'm using IPP 6.1. The only available API is ippiOpticalFlowPyrLK_(...)
My intention was to integrate optical flow of ippi into openCV 2.0.
Many thanks!!
BR.
Naveen_G_Intel
You are posted in the right forum, this forum specifically for IPP questions/discussions.
As I know Icv prefix is for for internal functions in OpenCv.
ippiOpticalFlowPyrLK is a right functions to calculates optical flow for the set of feature points using the pyramidal Lucas-Kanade algorithm. For more information about parameter for this function refer to,
http://software.intel.com/sites/products/documentation/hpc/ipp/ippi/ippi_ch14/functn_OpticalFlowPyrLK.html
Also, there is an example to demonstrate usage of this functions.
If you are intent to use IPP functions from your application, OpenCV provides a transparent user interface to the Intel IPP by automatically loading the Intel IPP libraries at runtime. For more information
http://software.intel.com/en-us/articles/intel-integrated-performance-primitives-intel-ipp-open-source-computer-vision-library-opencv-faq/
Naveen Gv
j3r3mi
Thanks Naveen for the prompt reply. FYI, i'm using OpenCV 2.0. I've already read the webby u provided sometime ago. If i'm not wrong its not applicable to OpenCV 2.0 as there's no path forOpenCV\cxcore\src\cxswitcher.cpp nor the file cxswitcher.cpp.
Anyway thanks for the reply.
